trans
when u can hear a clicking when u take off and shirt also sometimes when u go to take off it just clicks loudlly then starts movin. this is the transmission right?
It may be a fried rear diff
if u ahve the plastic diff housing check there first
locker
what about a locker it has a bruchless and didnt start it till today when my son ran it
cracked ouch
part time ur right the housing had a big ol crack right in the front. i think ill just replace int with a alloy one thats the only thing left that i hadnt made alloy yet.
motor
im runnin a semi bruhless motor called the grizzly have u had any dealing with a hacker full brushless?
The clicking, is the pinion gear in the diff slipping on the ring gear, when you hear a clicking like that, stop running, and it will likely save your gears so you can reuse them. Typicly, this happens when they aren't shimmed properly, or a bearing fails, etc... IN your case, its the differential case cracking, allowing it to spread out, making it not mesh properly.
The UE 7.5 Diff cases with the stock gear setup could, should do you fine.
- You may not post replies
- You may not edit your posts
Forum Rules
