+ Reply to Thread
Results 1 to 13 of 13
    Oct 2003
    7
    Question what the problem is??
    i have a 15x2 turn jaguar(peak racing)motor im my epede, that is all i have done to it to effect its performence.i run it with 1500 and 3000 batteries. before i could get the front end up with some help, but now i can`t get it up no matter what i do,whats the problem???
    Banned by Warnings
    Feb 2004
    VA
    815
    Most likely its your batts. I have the same problem with my pede. I was using cheap'o batts. (peak racing infact) and they hardly got my brushless pede to wheelie. Get some good 3300's or 2400's and you should be back to wheelie'n.
    Oct 2003
    7
    the 3000 is brand new and is a venom racing batt , could it be my gearing?
    395
    whtas ur gearing, what surface r u running on, what tires do u have? also does ur motor need a comm cut or new brushes?
    to buy or not to buy. Upgrade?that is the question
    pedy
    Guest
    dose your speedo go down that low of turns?gear down to 13or12\87.
    Banned by Warnings
    Feb 2004
    VA
    815
    Are your tires glued, how tight is your slipper...
    Oct 2003
    7
    im runnin it on asphalt, batts are new and fully charged, haven`t touched the gears,tires are glued,trucks not even a year old yet, motor should allow it to pull a standing wheelie, but it still won`t help me.
    Banned by Warnings
    Dec 2003
    South Georgia
    359
    those venom batts arent exactly the best quality are they now guys!? That motor should let you wheelie... if you gear it correctly! try 12/87
    your slipper could be too loose.
    395
    iff they are stock tires you may not be getting the grip you need
    Jul 2004
    Michigan
    24
    - Get masher 2ks
    - Change your gearing
    TRAXXAS Stampede
    Formerly Shimzuka on the TRAXXAS Boards
    Nov 2003
    New Hampshire, USA.
    1,261
    My rustler wheelies on 4 good cells with my streak ESC and titanite motor and 15/84 gearing.Top end is very slow but wheelies easy.( I do put the four cells way back in the chassis. I dremeled out the MSC/ESC mount). It has small stock size tires too. Get some good batteries , you will be amazed.
    Nov 2003
    Ohio
    249
    My brothers stampede wheelies with an SGP Amber (geared 15/87) at a stand stop with only Mashers (not 2000's), but he also has good Panasonic Heavy Metal 3000 6 cells packs, so this should mean the only thing you need (if you change the obvious changes needed), is good packs, GP, Snayo, or Panasonic like I have. Goodluck.
    "Life is just one big question mark" -RIP Indian Larry ?
    Feb 2004
    VA
    565
    Maybe try a little motor maintance? How long has it been since you did a little maintance?
