+ Reply to Thread
    Nov 2003
    Sterling, IL
    161
    Urgent question about pinion gear installation
    I've soldered my caps on the MM, broken in the motor, went out and bought the right size allen so I wouldn't strip the grub screw.
    When I install the pinion on the shaft, and I'm looking at the truck from the rear, the pinion only contacts the right side of the spur gear, maybe about 33%.
    Is this right? I can't move the pinion gear any further down the shaft...it's as far as it can be so the grub screw still contacts the flat part of the shaft.
    *Ahem* It seems to fit much better when it's not installed backwards. :-)
    RPM bearing carriers and 5x11 bearings, wide front bumper
    HiTec MG645 steering servo, Camber turnbuckles, Mag. Mayhem
    RC Turnbuckle Jr. razer's Avatar
    Oct 2002
    Streetsboro, Ohio
    15,087
    Flip the pinion over so that the setscrew is right at the end of the motor shaft. It should line up better.
    There is no chicken knife. Eat steak.
    Jan 2004
    Near Pleasant Hill, MO
    517
    It's hard to understand what your saying, but it I were you, I would put the pinion on backwards.
