+ Reply to Thread
    Apr 2003
    Rogers, Minnesota
    220
    Antenna replacement help
    My E-Maxx's antenna has broken off at the end of the plastic support rod (there used to be about 4-6" of antenna wire hanging off the end). Anyone know where I can get a replacement antenna and how to replace it? Can I just use a particular type of plain wire? I can't see an easy way to disconnect it at the base - do I have to open the receiver and disconnect it from inside?
    Thanks,
    Rob
    Feb 2002
    Vista, CA
    1,245
    Easiest place to get a replacement is from your local hobby shop, assuming you have one nearby. It's a common item they sell for a couple bucks. You have to open the receiver case carefully and be able to solder, or ask them and they might be able to do it for you.
    < How do I edit my signature??? >
    May 2003
    Sacramento, CA
    297
    If the antenna wire just snapped in half and I still have both halfs is there any problem with just soldering it back together? Probably a dumb question but just want to be sure
    E-Maxx owner as of 5/27/03
    Traxxas Tranny Plate and Team Associated Heat Sinks...other than that "bone stock and learning how to rock"
