I just installed the 645mg servo and also purchased a Kimbrough servo saver. What do you use to get the servo gear to properly mate with the servo saver. I installed the little black "hub" with internal and external teeth and it stripped out on the metal gear side after a two minute run.![]()
With it stripped out the steering does not work![]()
jeremy in minneapolis
