+ Reply to Thread
    Jan 2001
    central,pa,us
    894
    nitro zagi project
    i have a zagi 400 and the speedo and motor fried. i looked down at my norvel .049 sitting in the droor as i grin. i decided to mount the nitro engine in the zagi only problem is i cant get a good mount what should i do.
    IN GOD WE TRUST
    Feb 2002
    386
    if you have a dremel and a small tap you could make one out of aluminum, plastic, or even light ply. I dont know how a motor mounts in the zagi but i do know about the norvel engines (which i love). On my lmh the norvel mounts to plywood. Hope this helps
    Sep 2003
    abingdon MD
    494
    no idea wayt ur talkin bout, put a linc to a zagi
    I.M. at sixtoes1313 for r/c help
    Aug 2003
    Nor*Cal
    199
    hmm... I dont think the zagi was designed with a nitro engine in mind. why tear it up with that? They go so fast with electricity. Wont the Nitro engine mess up the COG?
    Never explain--your friends do not need it and your enemies will not believe you anyway.
    Elbert Hubbard (1856 - 1915) Every Message Board Needs a Psyco
    Apr 2003
    Ill
    252
    Im with him, what are you guys talking about? All Ive got is your trying to take an electric car and make it nitro?
    Jan 2001
    central,pa,us
    894
    sorry i should have said, it is a flying wing airplane, with pusher motor system.
    IN GOD WE TRUST
    Feb 2002
    386
    You also have to take into effect prop rotating direction. It would be funny if you started it, tossed it, and it came back at you . You can balance your cg with a stand from great planes. With a .061 or .074 norvel you wont tear it up. They only have about .3 hp. Another thing is exhaust. Conventional airplanes run it streight back but with the pusher prop.........it will be in the prop.
    Jan 2001
    central,pa,us
    894
    i have a pusher prop on it i turned the muffler around, that is not my problem my problem is takeing a aluminm engine and mount it securly to the foam wing.
    IN GOD WE TRUST
