+ Reply to Thread
    Sep 2003
    Cali
    74
    Question What Gearing for this Motor?
    What would be a good gearing for a P2K2 Pro Dyno Tuned Motor?
    Pinion = ?
    Spur = ?
    I want a gearing that will make the motor last and keep the heat down.
    Thanks
    cf_stampede@netzero.com
    RC Turnbuckle Jr. razer's Avatar
    Oct 2002
    Streetsboro, Ohio
    15,087
    The answer was found in the FAQ.
    Question: How should I gear my motor?
    Answer: As a general rule of thumb, you want a pinion gear that is 2 teeth less than the turns on the motor. For example, if you have a 17T motor you'll want to start with 15/87 gearing. If the motor and ESC aren't running too hot, you can go up a tooth at a time on the pinion to get more speed. Running in grass makes the motor work a lot harder, so if you primarily run in your back yard, drop a couple of teeth on the pinion. Your motor and batteries will thank you. If you are using a stock 27T 24° racing motor (like a P2K, or MVP), you'll want to use a 15 or 16 tooth pinion.
    In review, that's a 15 or 16 tooth pinion with an 87 tooth spur.
    There is no chicken knife. Eat steak.
    Dec 2002
    MA
    1,721
    I haven't experimented much with stock motors. Tosses the "two teeth less than turns" rule-of-thumb out the window huh?
    So many toys, so little time to use them.
    Former Member- 4x4 Pede Owners Club
    RC Turnbuckle Jr. arceeguy's Avatar
    Feb 2002
    Central New Jersey, USA
    13,880
    A stock racing motor geared 25/87 wouldn't last too long, after all, there always has to be an exception to the rule.
    A Stock racing motor needs to be geared low for "bashing around" because they tend to run hot. They are designed to sacrifice efficiency for more RPM/power, and in a racing situation, they only need to run for 5 minutes. You can actually gear up a few teeth from the recommendation, but you will have to stop to let the motor cool off before a typical battery is spent.
    Speed costs money, how fast do you want to go?
