+ Reply to Thread
    Sep 2003
    abingdon MD
    494
    Angry not getting fuel
    after fixing everything else my cousins 4tec doesnt seem to be getting fuel! would it have anything to do that the lines were cut shorter then original? help!!!!!
    I.M. at sixtoes1313 for r/c help
    Sep 2003
    abingdon MD
    494
    would a ripped coupler have anything to do with it. like wen u go to prime it it might not have enough compression to push fuel into the carb
    Registered User OneBigMan647's Avatar
    May 2002
    Calabasas, CA
    5,579
    Yes, a ripped coupler can very well be the problem. Tell him to immediately replace it. If it still continues after he replaced the coupler then the problem is else where.
    Dec 2002
    Tucson, AZ
    407
    if you take off the pressure line where it connects to the pipe and blow in it, does fuel get to the engine? check to make sure there is no cracks in the tank. otherwise, replacing the coupler should solve it.
    t-maxxwith2.5
    Guest
    His cap on the fuel tank might not be fitting tight enough against the rim on the tank so air might be leaking there and not providing the pressure required to push the fuel to the carb.
    ~John
