Has anybody ever put a motor with a stinger armature in their 4-tec. I know people have put them in rustlers and stampede's. I already have A motor like that, but I was wondering how they did in 4-tecs.
Sorry for the rambling post.
Project eBay T-maxx ultimate basher.
How does that work? DO you disassemble the motor can and swap the armature into a better one?
Yeah you just take the stinger armateur out and put it in a good one like you said. I put mine in a p2k2 pro can.
How does it run in other cars? I always thought it was a pretty stong motor for what it was.
It has awsome torque and top speed it runs better that a 17 turn motor.
Too bad I don't have any stingers laying around, That woould be something to try out.
i was thinking of doing that... which stuff do you use and how much is it?
thanks
4-tec and Stampede owner LOLOLOLOL
What do you mean, all you need is a stinger armature, and some motor can. I had to use a dremel to open the stinger can though.Originally posted by Lazlow
thanks
I used a pair of tin snips to get mine out. I put the arm in a 13x3 SG can and wow was that thing cool. I had mine in a srt. I did not have a 4-tec at that time.
I bend the tabs back on the endbell...lay the stinger on cement and give it one good pop with a hammer towards the end bell side ...the end bell usually pops right open...I put mine in a SG pro Amber can...batteries last longer and my Stampede was popping standing start wheelies geared 15/87...now it's in my boat and performs quite well
If you live in or near Chicago please check the "chicago" thread in the track/buddy locator section and come bash with us - go to the last page for the latest or read the whole thing - later
This sounds like a cool idea. I wouldn't mind trying it with my D5. I wonder how it would run?
Andrew
All side view mirrors should say "Objects in mirror are LOSING!"
I think the real difference will be in the magnets and brushes the donor can uses, like a stronger magnet which I think is the big difference and maybe a P-94 endbell with the larger brushes. I would be interested in seeing what a 24 degree, rebuildable, stock can and endbell would do for it though.
I was thinking, what if you took just the arm with out the wire and wrapped some, say, flatliner wire around it and made it into like a 10 turn or something. Or even use the same wire, but make it stock. That would have some interesting results. It would really be a "modified" motor.
Andrew
That has already been tried, and the motor ussually gets destroyed because the wire comes off.
Oh, ok. I guess I could see how that could be a problem. But it would be interesting if you could do it and have it work. You would just need to know what you were doing.
Andrew
