+ Reply to Thread
Thread: body fan
    Jul 2003
    274
    body fan
    is it possable to put a little fan on the top of the inside of the body to cool off the electronics, just an idea....
    Go ahead, we'll laugh at your failure....
    Jan 2003
    Dayton, (the weather stinks here) Ohio Totally useless
    682
    pretty much a waste of time. a fan that would move enough air woud be to big and bulky. you should get enough airflow under the body while it's rolling. (try drilling a big hole in the windshield with a hole saw like i did.)
    D
    MR PIBB AND RED VINES EQUALS CRAZY DELICIOUS!!!...DRIVE IT, BREAK IT! DRIVE IT, BREAK IT! (repeat as needed)Stock T-Maxx, two E-Stampedes,& E-Rustler... I-speed 12T, D5 13x1 flatliner in one pede. p-94 13x2 and a super chicken in the other pede.Airtronics MX-3 FM, NOVAK SS5800 in da rusty!!!
    Jul 2003
    274
    yeah, ur right. i have this body im gonna try to use, and i cut all the windows out, that should circulate sum air
    Nov 2002
    Parma, Ohio
    810
    actually I made a little fan unit that mounted in front of the xl1 and put a switch in the back powered by a9v battery and it kept it cool. I did this because I raced it and it would get super hot.
    whoo back in action....It's been too long.
    RC Turnbuckle Jr. arceeguy's Avatar
    Feb 2002
    Central New Jersey, USA
    13,880
    I was thinking of doing the same for my XL-1.
    I've got several small fans meant for Pentium heatsinks that would be a perfect size. i was thinking of splicing it into the main battery harness, but the fans are designed for 12 volts - so I'm not sure they would cool effectively when run on 7.2 volts. But I guess any extra cooling will help the XL-1, especially running a 17T motor.
    Speed costs money, how fast do you want to go?
    Jul 2003
    274
    where exactly do u mount the fan?
    thanx
    Nov 2002
    Parma, Ohio
    810
    I made a harness for the fan as well after I lost the battery jumping. I had it connected to the ecs plug so when I plugged in the battery I would not have power until I flipped the switch. It will run fine on 7.2v.
    Also mount the fan how ever you want I made a aluminuim mount and screwed it to the chassis where the msc mount goes.
