+ Reply to Thread
    Mar 2003
    The great and boring state of KANSAS
    176
    Black Oil And GArlging sound
    hey got a lil problem here "
    a black oil is leaking from the ezstart casing and a gargling sound when i go full throttle. it won't even go full throttle jsut a gargling sound.
    Pictures at http://community.webshots.com/user/cwank23
    RC Turnbuckle Jr. Klitch's Avatar
    Jul 2002
    Benton City WA
    3,003
    uhm your bearings probably wearing out allowing the crank to wobble a bit and the con rod scuff the mill.
    i read somewhere that when aluminum wears down it turns black.
    need m16 help/opinions? shoot me a email or icq me (click profile)
    http://community.webshots.com/user/klitch
    More pics - http://users.adelphia.net/~cledab/
    Banned by Warnings
    Jan 2002
    York, PA
    988
    Lightbulb yes klitch is write...
    Klitch, you probably read the, aluminum turning black when it wears, from one of my earlier posts; I talked about that a few times before. CWank, it's a good possibility that Klitch is right on this one, something like that happened to me before; I think my connecting rod bushing got oval shaped at the bottom and started to wear against the crankcase inside. I have noticed when I used to run my trx pro .15, the backplate would always get black oil on it, but if you are having a tinging noise, something isn't right. If your engine sounds "normal", is just gargling like it is rich, and the black oil is only on the backplate; I would just say it is running rich. If it sounds abnormal and you have dark black oil coming from the exhaust, something is wearing away in the engine.
    RC Champion PulsarD's Avatar
    Mar 2002
    Washington
    1,763
    Im pretty new to the stinger pipe, but since you have alot of oil that builds up in the pipe, isnt it a good idea to twist and turn the whole truck every now and then to drain it?
    I could see where after a while you might build up enough to cause a problem...
    Any ideas?
    PD
    By caffeine alone I set my mind in motion, By the beans of Java
    do thoughts acquire speed, hands acquire shaking, the shaking
    becomes a warning, By caffeine alone do I set my mind in motion.
    May 2002
    !FANTOM RULES!
    609
    PD
    with a pull start running a stinger it is prolly a better idea to reamove the entire header and blast air through it cleaning the remaining oil out of the header, I say with a pull start because you have NO ez start to remove which is annoying after awhile.
    !more power to the people!
    !feel the power..feel the fantom!
    IM EATING MY JOLLY RANCHERS...
