+ Reply to Thread
    Nov 2002
    LUTON/ENGLAND
    347
    Blue thunder or race formular
    ok, i use race formular and i learnt the other day that the normal blue thunder has a lean detecting shut off point, but the RF doesnt, so i was thinking that blue thunder origanal was better for bashing, is this correct?
    HELLO HELLO WE ARE THE LUTON BOYS!
    Jun 2003
    PA
    59
    i think you answered your own question
    Dec 2002
    637
    DYNAMITE BLUE THUNDER & RACE FORMULA FUEl
    original formula
    The original Dynamite Blue Thunder fuel was
    formulated by world-renowned engine expert Ron Paris nearly 6 years ago. The goal was to develop a car fuel that would quickly cause the engine to come up to operating temperature and allow correct tuning of the carburettor within just a few laps. It would then maintain that temperature throughout even the longest of mains.
    In addition special temperature sensitive additives were used that actually vaporize at specific heat range thus giving Blue Thunder "over lean protection" preventing damage to your engine. With Blue Thunder's original formula, if the carburettor is adjusted to an overly lean setting, the engine will hesitate under hard acceleration, like off slow speed corners, indicating to the driver to pull into the pits and richen the needle settings avoiding damage to your engine.
    This is Blue Thunder's unique Thermal Overload Protection at work making it the perfect fuel for sport racers. Thermal Overload Protection prevents racers from overheating their engines due to an overly lean needle setting which could cause damage to their engine.
    Race formula
    Blue Thunder Race Formula is formulated for the serious competitive racer that wants to get the most out of his engine. Race Formula features an increased castor-to-synthetic oil ratio with additives that allow race engines to be leaned to peak performance. This castor-enhanced formula also allows broader needle settings, that let experienced tuners tweak every last bit of power from their engine. Because Race Formula can be run at these lean settings it's possible to squeeze an extra 20 to 30 seconds of fuel mileage out of each tank.
    Blue Thunder Race Formula has been extensively tested by top on and off-road racers around the country including the Paris Race Team. Out of the experience gained from testing and racing for over two years now, several key benefits of Blue Thunder Race Formula have been verified.
    it works too motor got too hot and fuel started to vaporize and truck would not start till it cooled down and then richen it up...unless you are racing for pink slips..hahaha I would use the original blend
