COLOR=purple]dont let anyone tell me you cant put a rear exhaust on a 2.5 rusty![/COLOR]
still have the old rusty!!! new aluminum on the way
Nice idea taking that T-Maxx Header and putting astinger pipe on the end.Have you tried running it yet?![]()
Got nitro?
runs wicked, close to 64mph with the gears, 23t cb and 66t spur! and will still ride the wheelies! i love this truck
AWSOME!!!What type of tires are they?![]()
Got nitro?
looks good. i think the tires are dirt works.
how u fit 66 spur on a rusty??
nice
Drew
Got the 2.5R Jato running again!! RIP Rustler
hey ezags1, your right, they are dirt works, and for the spur gear i have a 23t cb to make it fit, top end is unreal!
here is just a peak at the topside of the rustys front end!
did you have to cut the maxx header to get it go fit. can you buy that pipe by its self or does it come in a kit
AIM: jonny101abc
Bad,Black, and Blown
89 Ford Mustang. 5.8L 682 RWHP
Thats awesome.
Steve
You break it, you buy it
hey johnny101abc, yes i cut the tmaxx header to make it work, and i dont know if you can buy the stinger w/o the kit, i had it for my pro 15 mip stinger kit! now i will have a stinger on both! and thanks flash! i think so to!
thats a good idea i htink i migth try it myself so i would need a new shock tower i ahve a stinger pipe a t-maxx 2.5 header and thats all right? (i have a coupler)
you know your into r/c's when u go to the doctor and your doctor tells you your blood has 20% nitro in it
i found out you can buy just the stinger pipe her ei is on tower
http://www2.towerhobbies.com/cgi-bin...?&I=LXRH08&P=7
hey bpm2007, if you dont have a rear exhaust shock tower here is the one i sugest http://www.rdracingproducts.com/view...r&color=Blue#, that should be all you need!
for anyone who doesnt have the header for a tmaxx here it is!http://www2.towerhobbies.com/cgi-bin...?&I=LXDDT8&P=7
hey bpm2007, where in ohio are you?
i doubt the truck goes 64! THAT IS PRETTY FAST. the 4 tech goes 60 i dont think changing the gears to 23 t cb and 66t spur will make it go 15 mph faster!
think all you want and that was your problem! it would be like going from a 3.73 gear in a real car to a 2.73, to give you an idea (just an example on the gear, i am not sure what the final is)
that is fast and the rustler wont go that fast no matter what gears you put in!
take that back! rage aganst the rc10 got his rustler up to like 71! it is possible just try.
guess i am not the only one aver 60 mph! lolOriginally posted by nitrocarmsn
How do you know that you are reaching these speeds? Are you taking a guess, or do you have a radar gun? Just wondering, thanks.![]()
He might be doing the other test. You take the number of seconds it takes to run in a certain amount of feet and multiple / divide that number to give you a close calcualation on speed. I did this (forget the formula) and did it 10 times and averaged it out to get a number.
Steve
my cousin is a deputy sheriff, access to a radar gun is easy!
FWIW I've made the speed trap test a little simpler. You can use the formula or the online calculator. Both can be found here.He might be doing the other test. You take the number of seconds it takes to run in a certain amount of feet and multiple / divide that number to give you a close calcualation on speed. I did this (forget the formula) and did it 10 times and averaged it out to get a number.
Be vewy vewy quiet,
I'm hunting trolls...
i did it it runs so sweet i ahev alot more traction off road but what i did different was take my stock header and flipped it around so it was pointing backwards then i took the stock pipe off and took my friend stinger pipe for his t-maxx and stuck it on the header and put the stock stock t-maxx coupler from the very first version and stuckc it inbetween the pipe and header and it works its a lot louder but sounds cooler and the only problem i had was that my coupler ripped because it was so old and crusty well sryi dont have pics my dad is getting a digital camera soon
hey bpm2007, i did it like that originally, and yes it did work, but i had the shock tower so i made the shock tower work!
yeah i didn thave to the shock tower so i winged it its really nice and loud i liek it a lot
