+ Reply to Thread
    Nov 2002
    Greenville Pennsylvania
    119
    Please help engine wont turn over!!
    I have the 2.5 Rustler and when the glow plug is in it wont turn over but when it is out it will. What can i do it wont start what could it be?
    Dec 2001
    Eau Claire, Wisconsin
    335
    your engine may have too much compression. You should loosen the glo plug. When you get it started, you tighten the glo plug and continue with your day. If you forget to tighten it, it will stop running after about 5 min. and it will look like you started the glo plug on fire, or you will see lots of gas all over the place
    Hope this helps
    -Andy
    Jan 2003
    California
    499
    Do you have a good battery that's fully charged? It might be that the motor isn't getting enough power to turn the engine over. If not, just do rustlerboy said and you'll be fine.
