+ Reply to Thread
    Jan 2001
    51
    Angry the gear turns but the wheels dont
    i ot a prob. when i start my car the spur gears turns but the wheels dont move at all and when i lift the back end off the ground and give it gas they spin, whats up with that does anyone know whats wrong it happend today my car has been fine untill then can someone help
    Jan 2001
    Montville, NJ, USA
    286
    Post
    Your Yokes maybe loose which can cause the lost in torqe also tighten the nutz for the wheels also you may have to check the gears in the transmission you may have to replace the ones that are losing their teeth thats probaly the problem but its a real problem to do check the nutz and the yokes first and tell me what happens
    Feb 2001
    Bend, Oregon
    1,666
    Post
    Check to see if your slipper cluch is to loose.
    Jan 2001
    warrensburg
    356
    Cool
    you probably just have to tighten the slipper cluch.
    GO NITRO OR GO HOME
    Jan 2001
    51
    Post
    how do u tighten the slipper cluch
    Jan 2001
    central,pa,us
    894
    Thumbs up
    there is the spur gear than a hevy spring then a nut tighten the nut to keep it from moving keep the wheal for moving or hold the spur gear
    get back it's a killer
    Jan 2001
    central,pa,us
    894
    Post
    now that is think about your biging stament the read/purple studs in the holes in the spur gear might b worn down
    Feb 2001
    hixson, TN, USA
    37
    Post
    try looking in the transmission, inside the differential. it is probabily the planetary gears. i had to replace mine 3 times.
    Traxxas Employee Nitro Chicken's Avatar
    Jan 2001
    Chicken coop
    5,993
    Post
    Be sure to check the slipper clutch. Always check the easiest thing first. DG is probably on the right track though. If the wheels turn when the car is off the ground but stop when you set it back down, it is probably a loose output yoke. If you hear grinding and clicking it is probalby a stripped gear inside the transmission.
    Back up till glass breaks, then gun it!
