+ Reply to Thread
    uh oh pede
    Guest
    Battery and Charger Question
    Hey...I want to get a Micro RS4 for my birthday and I was just looking around and they suggest that you use this pack:Team Orion 6.0V Micro Pack NiMH Battery in the Micro RS4. Will this be any good in it? Also, it says that "It has a unique special red two pin connector. 20 AWG wire" It has a different connector and does the ESC have this kind of connector and also what charger has this kind of connector? Sorry for asking so many questions but I really want to get one of these and I want to make sure that I get the right thing. Thanks for any help.
    RC Turnbuckle Jr. Autodisco's Avatar
    Apr 2002
    Kent, England
    3,728
    Hi,
    With this pack you will need the Micro ESC to go with it, as this will have the same connector. As for the charger, you will either need to modify a charger or buy one that's specifically meant for a Micro, although I'm not sure if they are available.
    Hope this helps,
    Stan.
    http://www.autodisco-racing.co.uk/
    uh oh pede
    Guest
    OK...I was looking around and I found this... and it says "For a charger, use DTXP4100 (Duratrax Intellipeak Charger, which I already have). So I dont need to worry about a charger but you said that you will need a Micro ESC. But on Towerhobbies it says:INCLUDES: HPI Micro BMW M3 RTR, silver pre-painted BMW M3 body, slick tires, 3 sets of wheels, foam insert tape, 3 plastic pinion gears - 9 tooth, and 13 tooth, spare body posts, wheel nut tool, AAA battery adapters, body clips, foam body strips, 5 and
    10 degree wing mounts, servo arms, NiCD battery mounting plate, Battery connector, motor connector, 2mm allen key, box handle, antenna, HPI TX-2 radio system (pre-installed), Micro Pro Control Speed control (pre-installed) and manual. Did you mean that if I wanted to get more power or something? Sorry for any confusion and thanks for the help.
