+ Reply to Thread
    Dec 2002
    149
    how do you take off the air filter on the 2.5
    see topic. i have tried, but the zip tie wont let me. how do you do it?
    if it aint traxxas, it aint good. rustler with 2.5, mip, kelly shocks,22 tooth, 3 speed tranny, 70-75 mph
    Jan 2003
    Citrus Heights, Ca
    172
    lemans23,
    I watched the DVD when I first got mine, it says to twist it off at an angle and it should come off. You do not want to take the whole thing off, just the AIR FILTER itself. Thats how I do mine. I hope this helps.
    Thank You,
    Chris Luce
    E-Mail: mr_cluce@yahoo.com
    MSN: mr_cluce
    ICQ: 16748383
    EZBoard: http://pub27.ezboard.com/btotalrc
    RC Turnbuckle Jr. Misbehavin''s Avatar
    Jan 2002
    North Carolina
    16,917
    Cut the zip tie off. When you replace the cleaned filter assembly use a new zip tie.
    You remove the whole thing. It's much easier. That's also the way the book and the DVD shows it being performed.
    Be vewy vewy quiet,
    I'm hunting trolls...
    Banned by Warnings nitroboy543x's Avatar
    Nov 2001
    Long island, ny, smithtown
    3,275
    Mis'
    To clean it, take the larger portion of the cone off, the plastic pice, and pull the foam out. its harder to take out the foam though the little hole, and waste a zip tie all at the same time. i do the twist off at a angle method
    Dec 2002
    149
    yeah i got that. i cleaned it. now how do i put it back on? i cant fit the whole filter onto the carb attachment with the groove.
    Jan 2002
    North Carolina
    16,917
    That's what I do, however I find it's much easier to pull the cone and the hose off the carb body in one piece, and then pull the cone off to access the filter. It's much easier to assemble the whole thing back together if it's all off the truck. Trying to put the cone part back on while having the hose part still on the carb seems to take twice as long. At least for me anyway, and I also figure that's the reason the book and the DVD take that route as well.
    Be vewy vewy quiet,
    mattf
    Guest
    I tried taking mine off, and it would not come off with the zip tie on it. I had to cut the zip tie before it would come off.
    Matt
