High speed steering.
Does anyone else have trouble steering at speed? At low speed the steering is responsive and the truck turns well. At high speed I turn the wheel all the way, the front wheels turn, but it's like they can't get any traction and the turning radius is like 30-40 feet!
-thePsymbian
nitro rustler
you must notice that the nitro rustler is powerful and when you hit full throttle your front tires lift a little...you prob cant see it but it does. Thats why your turning is hindered...also if your using the stock front wheeles like i am then they dont grip as well.
if you want more responsive stearing and better front end traction, get bearings in the stearing, and put hevyer oil in the rear shocks and lighter in the front. your car will stick to the ground much better ande your stearing will be very responsive.
Kn + Kn -> Kn2: see periodic table...
My steering is also slow and I've upgraded to ball bearings, Big-bore shocks, Lighter oil in front and sticky tires and it's still slow! Any suggestions?
what surfaces are you running on? mine works great. what sort of survo are you using?
your servo gears might be stripped if its really slow
I have put very thin oil in the front shocks along with soft springs... When turning on pavement the truck hooks up well and the inside rear wheel leaves the gound and sometimes will just go into a barrel roll...
I am not using stock tires... I have the f/g shock towers, big bore shocks, and proline tires with ball bearings all the way around...
Alsop get a hi torque servo
Dude lay off the 60 percent!
You need softer springs on the front shocks.
Traxxas red springs work well.
[This message has been edited by rugermann (edited 01-24-2001).]
- You may not post replies
- You may not edit your posts
Forum Rules
