+ Reply to Thread
Results 1 to 10 of 10
Thread: speed/control
    Sep 2002
    Clarksville,Indiana
    522
    speed/control
    alright i want my car to perform fast but would i have to sacrifice handling for that because i want good speed and tight handling so what do youall suggest i do because i want a good car with awesome speed and handling before i graduate to a street sport or nitro 4 tec but between those two what do you think i should get nitro or electric. also out of my battery pack (1500) how long should i be getting out of that if i charge for 30 minutes. thanx.
    paul
    I am the one the only.
    {edited}
    PONTIAC TRANS AM RAM AIRS/FIREHAWKS look the best, feel the best, sound the best, and are the best. {edited}
    Sep 2002
    Clarksville,Indiana
    522
    ok
    hello any one there
    {edited}
    Jun 2002
    Eau Claire, Wisconsin
    224
    Think about it if your going 100 mph and you crank the steering wheel all the way to the left whats going to happen? your not going to make a hard left turn are you? You half to blend speed and handling toghter. For better handling get some good tires and a sway bar kit. AS for a electric or nitro it kinda depends on the track electric cars are good for short tracks cause they come to speed quick, nitro need a little more space to get to top speed.
    lots of things depend on how long the battery will last get a good peak charger that way you will know it will be fully charged. I never charge my batteries for more that like 10 minutes if your charging for 30 minutes you must be using a low voltage for charging.
    Sep 2002
    Clarksville,Indiana
    522
    k
    alright well what kind of engine and speed control should i get and is my battery getting a good charge to it butdo i need to get a new charger
    paul
    {edited}
    Jun 2002
    224
    Get a novak or LRP speed control, with a no motor limit and for a motor go for a 8-9 turn double motor like a trinity, or Reedy motor. And a 1500mah battery wont cut it,go for a 2400mah or a 3000nimh battery. And dump the old charger get a good one like a novak, ion charger what way u know the batteries are peaked.
    Sep 2002
    Clarksville,Indiana
    522
    k
    alright well thanks for the info and what should i do bout a discharger for my battery and how much does the charger run
    paul
    {edited}
    Aug 2002
    The old pg of MD
    179
    Well I can't help you in steering. but a good cheap peak charger is the MRC Super BRAIN at 46.99 at tower hobbies or the Duratrax digital peak charger at 49.99 at tower hobbies.
    note: electric cars don't have engines. they have motors. If you really want speed, I would first learn the basics of gearing. then you go ahead and buy a 10-turn motor with 3 or 4 winds. that will get you top speed without putting wear and tear on ur car. you might as well get the type of esc that was listed before. for a discharger, just run your car till it slows down significantly to the point that it "stutters" alot when you accelerate.
    Sep 2002
    Clarksville,Indiana
    522
    cool
    alright i got the name of the parts now how much will i be looking at in spending for this stuff and if any body has any more suggestion feel free i need all the help i can get, oh and i have made 1 mod to the thing besides bodies and wheels i got aspur gear with 84 tooth so im startin small and workin up so is that smart.
    PAUL
    {edited}
    Sep 2001
    645
    lets see:
    motor: $60
    ESC:$100
    charger:$80
    3000mah batteries (2): $140
    so ud be lookin to spend around $380 for all of that. then u gotta think about getting proball diffs and the steel output yokes for them because the stock ones just wont hold out with an 8 turn motor. so thats $120 more. its a really big investment.
    4TECPRO15
    Guest
    I have a speed gems 2 15 turn motor and a novak explorer II speed control and let me tell you my car will fly
