+ Reply to Thread
Results 1 to 2 of 2
    Mar 2002
    Seattle, Wa.
    189
    Fuel gone bad? and other questions (long)
    Whats up drivers,
    I'm just sort of looking for some feedback here... I've run 1 gallon through my rustler. about 3 weeks ago it started giving me a lot of problems, starting it and keeping it running. It starts OK but dies quickly, sometimes when I remove the glow plug warmer and sometimes when I open the throttle for the first time. Once I can get it running and warmed up, it seems to be fine- but this has been taking 30 minutes of starting it and having it die over and over.
    I thought it might have been my exhaust, but just to make sure, I just did sort of a full overhaul. Here's what I did:
    -new AE pipe, perfect fit header, new gaskets and coupler.
    -new shims under cooling head (left the thinnest one out)
    -new mcCoy mc9 glow plug
    -all new fuel tubing- thinner tubing for a tight fit on fittings
    -removed fuel filter (maybe it was clogged?)
    -cleaned out engine, carb, HS needle out with carb cleaner spray.
    -sealed base of carb and base of HS needle nut with RTV.
    -reset carb to factory setings.
    -raised idle as much as possible, without having the car scoot forward while idling.
    -re-charged batteries in my EZ-starter and separate glow-plug warmer.
    Still starts like
    What I'm wondering: My fuel is the last pint of 1 gallon, monster trinity %20, first opened maybe in April. I keep it outside, keep it capped, but the jug has been 3/4 empty now for 2 months. Could it be that my fuel has gone bad?
    Any other ideas?
    Oct 2001
    LUTON/ENGLAND
    1,877
    it could well have gone bad get some more fuel and see if it makes a diffrence lets hope.
    David Wright.
    take it to the red line
    Junk is something you keep for years and then throw it away 3 weeks before you need it.
    rustler rules the rc world
    aim is wdave13 plz
    nitro_dave15@hotmail.com msn
    i dont like the new desert storm why? cause power is nothing with out control
