Results 1 to 8 of 8
Thread: Help quick!!
    Jan 2001
    Baton Rouge, LA
    92
    Exclamation Help quick!!
    I just got a Nitro Sport from a friend. The settings on the carberator are messed up and I need to know how far to unsrew those two screws. The big one and the small one. Please explain in detail, im new to this
    Feb 2001
    Salem, IN
    33
    Wink
    The big screw on the back needs to be turned 2 1/4 turns from being all the way closed (turn it clockwise tell it won't go no more do not over tighten and turn counter clockwise 2 1/4 turns).
    The little screw beneath where the air filter is, is for the idle. Pull the air filter off and the opening where the air gets sucked in should be approximately 1-2 mm open.
    I believe I have all this memorized right if not somebody please double check.
    Thanks
    Jan 2001
    Colorado
    138
    Post
    the idle should be turned 1 3/4 from closed 1 1/2 for high altitude. im pretty sure
    Nitro good, Batteries bad.
    Jan 2001
    Fremont, OH
    17
    Post
    I always thought that too but I couldn't even get mine to start with that setting. I had to turn mine out like 3 1/2 turns before it would even start. Go figure?
    Jan 2001
    29
    Post
    Sounds like you have the trx-15 pro if you have both a low and high idle screw. The sport engine has only the high idle screw. Make sure you know what carb. you have, because the stock settings are about 1 turn different, and will make it hard to dial in.
    Jan 2001
    Scottsdale,AZ,USA
    220
    Post
    How do you know they are messed up?????
    nitro rulez
    Jan 2001
    Baton Rouge, LA
    92
    Post
    i know they must have messed up in shipping because the engine keeps going dead when i gas it.
    Jan 2001
    Scottsdale,AZ,USA
    220
    Post
    Did you let the engine warm up before you gave it gas???
    nitro rulez
