+ Reply to Thread
    Jan 2001
    Colorado
    138
    Question where should i paint my body?
    should i paint it on the in or outside. ive heard a little of both
    Jan 2001
    Grand Blanc MI USA
    38
    Post
    definitly on the inside cause then the paint wont scratch and it looks shinier.
    Jan 2001
    3rd rock from the sun
    1,398
    Post
    its also less work from the inside.
    you can't say can't
    Jan 2001
    Colorado
    138
    Post
    thanx
    Jan 2001
    NJ
    77
    Post
    Some bodies come with an over spray film on the outside of the body. If you spray over that, the paint will peel off in one big sheet ya, inside is the only way to go. Be careful with your masks too. Use good masking tape and make sure the edges are down good or the color will bleed under the tape. You can use the edge of a razor blade to "iron" out bubbles too.
    Nitro Sport
    Pro.15 MIP 360 Stinger
    Jan 2001
    littleton CO USA
    178
    Post
    dude paint it on the outside of the body, thats what i did and it works great,just do it
    Jan 2001
    Truman,Mn,usa
    46
    Thumbs up
    You should paint the inside of the body. You will get a much better shine and if you take your time it isn't much harder than just painting the outside of it. Least the first time you roll it on the top and slide it for 5 feet or so, it won't look as bad if you painted the outside...(most paint for this type of plastic is made for the inside,the paint drys much more flat than it looks).
