+ Reply to Thread
    Jan 2001
    Grand Blanc MI USA
    38
    Post Fuel tank cold profing!
    ok this is my delima. i can run my sport in the cold and all but the only problem is that the cold hitting the fuel tank is making water condense inside the fuel tank which can be bad. so anyways does anyone know a way i can insulate the tank and keep the cold out? thanks!
    Nov 2001
    Utah
    92
    cool
    BORN-N-BRED TO RIP AND SHRED
    Nov 2001
    Utah
    92
    let me think
    RC Turnbuckle Jr. fanman's Avatar
    Apr 2001
    Auburn, Michigan
    3,503
    i have been running in the cold for a couple of weeks (just now in the snow, cause we just got some). i haven't had much if any problem with water condensing in the tank.
    Everyday I beat my own previous record for number of consecutive days I've stayed alive.
    http://community.webshots.com/user/fanman_2000
    Feb 2006
    North Central Kansas
    104
    Maybe wrap it with a piece of insulated foam... something that bends to form. But still gives you access to the lid? Cut a notch out though along the side so you can see your fuel level. You know, sort of how it is on a bottle of motor oil. Zip tie it on!
    NewEraRacing Rear Shock Tower, RPM (Yellow) Lower Spring Cups, American CNC Head, RPM Front Bumper
    Dec 2005
    Palo Alto, CA
    2,201
    Insulation wouldn't help that much. It would help a little, but not really. Insulation helps trap heat inside the tank, but since theres not that much heat in there to begin with, it wouldn't really do anything. And also, I highly doubt water is condensing inside your fuel tank. You tuned pipe is constantly pumping piping hot exhuast in there. You should be fine, with or without insulation. Also, even if water is condensing, it's probably not enough to harm your engine.
    I hate E-Clips
