I got a e revo and wondering if ill be fine with these batteries
5000mah 2s 20c-50c
Also can you like mix batteries like throw a 3s venom 5000mah 35c I'm with it as well?
Printable View
5000mah 2s 20c-50c
banned brand i would correct your post and post this question on a different forum other than traxxas brandon..... reasons are known around here as to why just best to not talk about it. This is a heads up for a fellow member
PM sent so you will know for future reference.
As Mike said we're not allowed to talk about that brand here, they make and sell illegal copies of Traxxas products.
For your other question, no you should never mix non identical packs. Mixing a 3s and 2s is fine as long as they are the same brand, rating, age etc.
clean out your PM..........OP
I would go with a higher C rating then 20c like the ones I recommended in your other thread
Pm is cleaned out, i mean they are 25c to 50c
Okay guys sorry I'm new to this hobbie and don't know who has beef with who orv what we can't say i tried to edit first post but wont let me.
So basically my question is will the car do fine on 2 batteries that are 2cell 5000mah 25c-50c
Yes with proper gearing....
[QUOTE=87 GN;5412937]Yes with proper gearing....[/QUOTE]
Okay thanks so just monitor temps
First few runs watch the temps pretty close then you will know how your temps are & you are good to go.......
[QUOTE=87 GN;5412968]First few runs watch the temps pretty close then you will know how your temps are & you are good to go.......[/QUOTE]
That's again for all the help man! My buddie is using the traxxas lipos 2cell 7600mah and said hes getting good run time i may get those next.
I run the Traxxas 2s 7600's in mine, they're great.
[QUOTE=RobWilJas;5412982]I run the Traxxas 2s 7600's in mine, they're great.[/QUOTE]
Awsome where is the best place to get those at a good price
best place is where they have promo codes like towerhobbies sometimes, check out stormer, rcplanet, amainhobbies, nitrorchobbies i've found to most of the time be cheaper than towerhobbies.
[QUOTE=mike-susieq1;5413007]best place is where they have promo codes like towerhobbies sometimes, check out stormer, rcplanet, amainhobbies, nitrorchobbies i've found to most of the time be cheaper than towerhobbies.[/QUOTE]
Sweet thanks for the advice ill look into then all..
I got mine at tower with the club member discount.
