The speed chart below from Traxxas does not show the speed for the stampede 4x4 vxl with a 11/54 gearing on a 2s lipo. Does anybody know?
[IMG]http://i14.photobucket.com/albums/a340/kul_blu_car/SpeedChart_zps0ea8f308.jpg[/IMG]
Thanks in advance!
Printable View
Thanks in advance!
The title should be: [b]Speed for stampede 4x4 vxl with 11/54 (stock gearing) on 2s...[/b]
The speed chart above does not show it.
I believe the rule is that the less teeth you run on the pinion, the lower your top speed will be, but you will gain more low-end torque and acceleration.With that in mind and referencing to the chart, your speed would be under 40 for sure. Here's a speed calculator some people use. Just type in your info: [url]http://scriptasylum.com/rc_speed/top_speed.html[/url]
[QUOTE=dgudenau;5387931]I believe the rule is that the less teeth you run on the pinion, the lower your top speed will be, but you will gain more low-end torque and acceleration.With that in mind and referencing to the chart, your speed would be under 40 for sure. Here's a speed calculator some people use. Just type in your info: [url]http://scriptasylum.com/rc_speed/top_speed.html[/url][/QUOTE]
Thanks for the link man! I would want to change my pinion today to the 17/54 while running with the 2s lipo. Not advisable to run on grass huh?
I agree dgudenau, you will probably see around 30 MPH or so. That chart does show 11/54 on 7 cell nimh @8.4 volts. Your 2s is 7.2v but with a bit more punch from a standstill. If you're looking for speed, 11/54 on 2s won't really deliver.
