hey guys i have just recently gotten a new traxxas summit and i am wanting to put together a tool kit for it so i can fix on the run. are there any common parts to break that i should put on my list for my tool kit? replies would be great thanks :)
Printable View
The only thing i have broken so far on mine was the front bumper mounting loop. Summits in stock form don't go fast enough to break anything, they just get scratched up from rolling back down the hills you couldn't quite get to the top of hahaha :)
i would be an extra set of steering push rods, my son hit something and bent one.
Some good backup parts:
[URL="http://buy.traxxas.com/product_info.php?products_id=8457"][COLOR="#0000CD"]5655[/COLOR][/URL]: Half shaft set, short (plastic parts only) (internal splined half shaft/ external splined half shaft/ rubber boot) (assembled with glued boot) (2 assemblies)
[URL="http://buy.traxxas.com/product_info.php?products_id=8459"][COLOR="#0000CD"]5656[/COLOR][/URL]: Half shaft set, long (plastic parts only) (internal splined half shaft/ external splined half shaft/ rubber boot) (assembled with glued boot) (2 assemblies)
[URL="http://buy.traxxas.com/product_info.php?products_id=7827"][COLOR="#0000CD"]5352R[/COLOR][/URL]: Rebuild kit (heavy duty), slipper clutch (steel disc/ aluminum friction pads (3)/ spring, Revo (1)/ spring, Maxx (1)/ 2x9.8mm pin/ 5x8mm MW/ 5.0mm NL (1)/ 4.0mm NL (1))
[QUOTE=ksb51rl;5370731]Some good backup parts:
[URL="http://buy.traxxas.com/product_info.php?products_id=7827"][COLOR="#0000CD"]5352R[/COLOR][/URL]: Rebuild kit (heavy duty), slipper clutch (steel disc/ aluminum friction pads (3)/ spring, Revo (1)/ spring, Maxx (1)/ 2x9.8mm pin/ 5x8mm MW/ 5.0mm NL (1)/ 4.0mm NL (1))[/QUOTE]
Boom! This stuff! And aluminum pads are the way to go! I love um!
Sent from my DROIDX using Tapatalk 2
[QUOTE=DogMilk;5370751]Boom! This stuff! And aluminum pads are the way to go! I love um!
Sent from my DROIDX using Tapatalk 2[/QUOTE]I actually don't use them on my Summit, but I do on my Slash 4x4. On the big trucks (Summit and ERBE) I use a modded T-Maxx brake disk as a slipper disk:
[URL=http://i152.photobucket.com/albums/s181/ksb51rl/Summit/tra4964.jpg][IMG]http://i152.photobucket.com/albums/s181/ksb51rl/Summit/th_tra4964.jpg[/IMG][/URL]
how modded do you need to go? I just bought a pair of HR Double up Slipper kits. Was just about to buy some pads as well.
You need to ream out ever so slightly every other pair of holes around the circumference - or take an extra minute and do every hole.This allows the holes to fit on the small bumps/pins on the plate that usually hold the pads. BUT, the brake disk is thicker than the pads and may push the spur gear far enough out to contact the gear cover. I usually clearance the inside of cover with a Dremel sanding drum but one could conceivably let the spur cut its own clearancing path in the cover. Would be noisy for a little while.
ah ok, maybe ill just pick up some alum pads instead. i have spur cover clearance issues as it is with Mod1 anyways.
Tires can rip (repair with Super Glue), some people break bumper mounts, and it's always good to have an extra set of suspension arms. I have not broken any of these on my own Summit. My ERBE tells a whole different story.
I also would get your self a set of bearings. And If you want to spend money maybe a micro servo (2065) gear set and drivelines.
Tra5120 12x18 bearing
Tra5117 6x12 bearing
Tra5180 6x13 bearing
Tra2064 gear set
Tra5650 drivelines
thanks guys
I might add a screw set so in the case you do have to work on your summit out in the field and accidently lose one you'll have some spares.
Check eBay chop shops they're fairly reasonable and if you find a set for/from a summit you'll have all you should need.
Stay away from the junk stainless screws, they look cool but they're soft and bend/break
Sent from my iPhone using autocorrect
I suggest Tony's screws reasonable price for a summit set.
Sent using lipo power
I keep a set of front control arms a set of wheel bearings a set of the short and long driveshafts and the inner and outer parts to make one complete driveshaft.
thanks people
First thing I broke was the rear drive shift, and the front one was on the way out to. This happened about 1 week after I had it. So at least carry a spare rear one. I replaced mine with the traxxas steel ones then I twisted an axle up. So I'd carry some spares of those to.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Even though you can't swap in the field but if you happen to run across a cheaply priced diff buy it for later.
[QUOTE=bstromback2002;5371413]I keep a set of front control arms a set of wheel bearings a set of the short and long driveshafts and the inner and outer parts to make one complete driveshaft.[/QUOTE]
Do u have those part numbers?
[QUOTE=Keila72;5370859]I also would get your self a set of bearings. And If you want to spend money maybe a micro servo (2065) gear set and drivelines.
Tra2064 gear set
Tra5650 drivelines[/QUOTE]
Thank you for this info
nice. I just ordered my Summit. What tools will I need to work on it?
the summit comes with all the tools you will need to work on the majority of the car, so you dont really need to worry about tools bud :)
But you will want to invest in a set of hex drivers,trust me you will.
1.5 mm 2.0 mm 2.5 mm covers almost every fastener on the truck
yep, a guy can only use those L-wrenches for so long before you snap.
Set of hex drivers is a must.
[QUOTE=his grace;5372363]Do u have those part numbers?[/QUOTE]
5331 & 5332 for the front suspension arms
5653, 5654, 5655 & 5656 for the driveshaft parts. The only other thing I have broke is the output on the rear differential to right rear wheel. I drive it like I stole it so I'm kinda suprised I have not broke more stuff.
Okay, here is the set I ordered:
5x8x2.5 mm (1pc)
5x11x4mm (14pcs)
6x12x4mm (4pcs)
6x13x5mm (4pcs)
8x16x5mm (1pc)
12x8x4mm (4pcs)
Does that look right?
so the summit doesnt come with bearings?
[QUOTE]so the summit doesnt come with bearings? [/QUOTE] Nope. The Summit comes with FULL bearings. Except the motor bushings, (They don't count anyway) every thing on the Summit has bearings. :thumbup: You need to keep spares because some times the seize up with rust. :thumbdown:
thanks heaps for the replies i am thinking of getting a drive shaft set, a front and rear a-arm set, and a screw set should do me just fine. maybe some glue in case the tyres come off the rim
anything else to add?
Front long travel arms , front a arms and half shaft , and a slipper clutch ive got a new summit and so far this is all that has broke there tough trucks
+1 on the extra tyres, drive shaft, slipper clutch and diff set.
for the toolkit get some bearing grease (you can pack the bearings to give them a longer life and if you run in the wet a lot), motor cleaner (if stock/brushed), spray lube, rubber cement to repair tyres that sometimes get cut from sharp rocks, edges.
