Eliminate stripped servo gears for free!
Well after stripping 3 sets of sevo gears i finaly figured out why! Turns out the servo saver is very dry and
Suseptable to sand or dirt getting into it and taking the "saver" Out of the equasion. So simple fix? Yes take the skid plate off, remove the links from the bellcrank and the
servo link then pull the saver out(piece with the spring sandwiched in). Take out the two screws holding the saver togetherClean it out really well then apply a drop of silicon shock oil or bearing oil reasseble but leave the two small screws just snug. Put it all back together and bam! Servo saver actualy saves the
servo gears. Coming from two months heavy use on this current set of gears! Well worth the 7 minutes it
Takes!
