EREvo with MM 2650 System !
will it work good
as a matter of fact i m stuck with it ask my brother to order a 2200kv system and he ordered 2650 !
what will be the best gearing for it !
Printable View
will it work good
[QUOTE=reddy;5318453]EREvo with MM 2650 System !
will it work good
what will be the best gearing for it ![/QUOTE]
yes, it'll work great in it. i run the 2650 in my revo and i love it. I run 54/22 (sometimes 24) for gearing on 4S and it's as fast as a 2200 on 5S. no worries at all, it's a great system for the revo. i actually prefer it over the 2200 for this truck.
HEHEHEH !!! thanks ! my worries r over !
but mine is with Proline 40 series 3.8 tires
[QUOTE=reddy;5318518]HEHEHEH !!! thanks ! my worries r over !
but mine is with Proline 40 series 3.8 tires[/QUOTE]
me too. i run the 40 series badlands :) :thumbup:
lower the kv the more torque....
On 2/2S lipo with the 2650kv motor:
18/68 = 35mph
18/62 = 38mph
18/58 = 41mph
18/54 = 44mph
20/54 = 49mph
i think i will go for 20/54
with my old e-maxx tires (5.75's) and a 24t pinion, the speed calculator says i'm doing 64mph. with the 22T, 59mph.
here's the variables:
Enter Front/Rear Differential Gear Ratio:
Traxxas E-Revo - 2.85:1
* Enter Transmission Gear Ratio:
Traxxas E-Revo - 1.83:1
†† Enter Additional Gear Ratio :1
* Enter Spur Gear tooth count :
Traxxas E-Revo/3905 E-Maxx - 54T
* Enter Pinion Gear tooth count:24T
* Enter total battery voltage :
4.2v Lipo max
4 cells
* Enter kv rating of brushless motor :
Castle Creations 1512/1y 2650kv - 2650kv
* Enter tire diameter in inches :
Traxxas Maxx (old) - 5.75"
Spur/Pinion Reduction Ratio :2.25 : 1
Total Reduction Ratio :11.74038 : 1
Tire Circumference :18.06 inches (458.83 mm)
Rollout :1.54:1
Total Motor Speed :44520 RPM
Theoretical Maximum Vehicle Speed :64.87 mph (104.2 km/h)
[url]http://scriptasylum.com/rc_speed/top_speed.html[/url]
4.2v Lipo max 4 cells
I figure the Volts at 3.7v nom = about 5 mph difference
20/54 2/2s 48.86 mph 3.7v
20/54 2/2s 55..47 mph 4.2v
copy paste in link above ~ import
change cell count & gearing
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.8333333333333333
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 21
Total Voltage: 22.20
Motor KV: 2200
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 3 : 1
Total Ratio: 15.65385 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Rollout: 1.18:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 54.76 mph (87.97 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
I'm wondering why you chose 3.7? My lvc i set at 3.6. Now i understand your variables as to how you calculated your speed. Perhaps a mid range voltage would also be a good representation since we were calculating both ends of the spectrum of possibility.
my MM system came with M 0.8 pinion can i use this with erevo ?
[QUOTE=reddy;5321896]my MM system came with M 0.8 pinion can i use this with erevo ?[/QUOTE]
mod.8 and 32 pitch are the same so, yes you can use that pinion.
Technically speaking under load lithium batteries provide approximately 3.7V (nominal voltage).
Realistically using 3.7V as a battery voltage for those calculators is far more accurate than full charged voltage as there is serious sag under the loads the power system draws.
[QUOTE=humayrayakongkinaon;5322344]mod.8 and 32 pitch are the same so, yes you can use that pinion.[/QUOTE]
18t pinion came with system have to buy a new 1 :(
at last it arrives time to go monster mad !
[IMG]http://img.sceper.eu/images/4FEvh.jpg[/IMG]
picture not working, let me know how this motor perform i might consider getting this for my build.
[QUOTE=vxlrocket;5321426]I'm wondering why you chose 3.7? My lvc i set at 3.6. Now i understand your variables as to how you calculated your speed. Perhaps a mid range voltage would also be a good representation since we were calculating both ends of the spectrum of possibility.[/QUOTE]
3.7 v per cell so on so on.. Don't really have a good answer that is the preset voltage. I agree that is a bit low, but at the same time 4.20 is not a true voltage either, voltage drop. A happy medium say 4.10 or 4.0v maybe...?? What do you think. Might have to start posting the V, when posting gearing speed....
on my merv and neu 1110 1/y i was seeing drops below 3.4 and with the 9000kv motor to 3.2v
when i do some testing with the erbe with my eagle tree v4 /gps i will post some numbers running stock motor stock gearing and spc 5000 50c batteries
