Recharging Batteries
I have the TQi radio and I put 2200 mAh batteries in it so thats four 2200 mAh battteies at 6 volts. My question is where can I find a chart to tell me at what rate to charge them at and is there a way to mod this radio to accept a charging port so I do not have to take them out everytime I charge them.
Unless you can isolate the charger current from the radio, I suggest taking them out.
The battery should have charge specs on it... or at least have them available from the manufacturer; which is where you should be getting help from since this is a Traxxas forum for Traxxas items.
[QUOTE=Jimmie Neutron;5314077]Unless you can isolate the charger current from the radio, I suggest taking them out.
The battery should have charge specs on it... or at least have them available from the manufacturer; which is where you should be getting help from since this is a Traxxas forum for Traxxas items.[/QUOTE]
No need to be rude. I at least have them in a traxxes radio. And I just thought I would ask.
It was not my intention to be rude.
[QUOTE=jarchie;5314386]No need to be rude. I at least have them in a traxxes radio. And I just thought I would ask.[/QUOTE]
[QUOTE=Jimmie Neutron;5314390]It was not my intention to be rude.[/QUOTE]
Jimmie was simply quoting you the Traxxas policy. Unless the batteries used in the radio are Traxxas brand, his instructions are spot-on and not in the least rude.
You know what, just delete the darn thing. I didn't know it was going to cause such a stir.
It didn't. I apologize that you didn't get the answer you wanted, but there's no reason to react so strongly.
