So I'm changing over to 32pitch gears for my stampede but can't seem to find any online so if you know a site please let me know and what brands are good
Printable View
Use a jato spur and traxxas mod .8 pinions, starting at 14t or15t. I can post up the stk #'s later when I'm at my pc.
Use all the other stock parts except the cover, you won't need it.
Buy one 32p Jato spur TRA3956, and matching mod 0.8 pinions: 12t TRA3942, 13t TRA3943, 14t TRA3944, 15t TRA3945, or 16t TRA3946. You can also order smaller or larger mod 0.8 pinions as needed.
Thanks for the info I ordered 3 jato spur gears from tower and 3 pions that weren't traxxas just 32 pitch I hope they work
As long as the hole for the shaft is the correct size they should work. Traxxas and Robinson racing make good pinions.
[QUOTE=Chrisfoster;5308894]Thanks for the info I ordered 3 jato spur gears from tower and 3 pions that weren't traxxas just 32 pitch I hope they work[/QUOTE]
Running the VXL 3500 brushless?
You are good to go if you ordered the 3mm pinions. Typically stated as Emaxx pinions.
No I orders 5 mm because the tacon motor has a 5 mm shaft but now I might get some for the emaxx too
