What's the best fuel to use in the 3.3 engine? I saw the top fuel, but only comes in (4) gallon cans. Looking to get something in one gallon size but don't want 4 of them.
Printable View
Your LHS should have them in gallon sizes. I use Byrons, others use that or O'Donnell, Blue Thunder and a bunch of others.
Yeah, just went to the lhs. They had all kinds, I just went with a gallon of Byrons and a gallon of top fuel
I'm just curious, could one of these engines run on regular gas or diesel? I'm not gonna try it, but just wondering
[QUOTE]I'm just curious, could one of these engines run on regular gas or diesel? I'm not gonna try it, but just wondering[/QUOTE]Um, you can convert it to a Davis diesel, but it costs a ton, and the gas is about $40 a gallon. :eek:
[QUOTE=Wolfslash16;5290164]Um, you can convert it to a Davis diesel, but it costs a ton, and the gas is about $40 a gallon. :eek:[/QUOTE]
Thats cheaper than a gallon of 30% O'Donnell, but not worth it. I havent seen to many lhs that carry the fuel.
I watched a video, like nitro better
I very much like torco 20% fuel.
[QUOTE=jmcrane77;5290250]Thats cheaper than a gallon of 30% O'Donnell, but not worth it. I havent seen to many lhs that carry the fuel.[/QUOTE]
Wow, where are you getting it from? I just got a gallon of O'Donnell's 33% race blend for $28 @ my not so local LHS.:cool:
I get the same, but 30% for $10.99 a quart from lhs.
Do you guys know where I can just get the piston and not the sleeve and con rod? My piston skirt went into multiple pieces but I don't need a rod or sleeve yet
The piston and sleeve come in a set and at this point can only be purchased together. If your skirt let loose, there is the possibility that the sleeve is scored from the debris.
No, I swear, the sleeve is perfect. I'll try to just run it with the broken skirt until it breaks then get a new sleeve and piston, unless someone has a piston laying around. Hint hint!
