Waterproofing the mamba ESC.
Still waiting on parts to arrive...I thought I would include this in my new build thread.
Where I live it rains quite a bit and have sweltering humid summers. I am not a big fan of the outwears shroud so I went the Plasti Dip route. [B]Note*[/B] Doing this mod to your ESC will void your warranty.
First of all I cut the switch off...I kept having problems with it. This way I am forced to unplug my batteries when finished using my truck. I just soldered the 2 wires together to bypass the switch.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/ESC%20Mamba%20Monster/IMAG0262.jpg?t=1338459996[/IMG]
I then went and used electrical tape to cover the heat sink and plugs to protect while coating with Plasti Dip:
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/ESC%20Mamba%20Monster/IMAG0258.jpg?t=1338459515[/IMG]
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/ESC%20Mamba%20Monster/IMAG0257.jpg?t=1338459927[/IMG]
My advice is don't coat to thick or you will have issues trying to fit the ESC back into the cover.
This has proven to be very successful in running in wet conditions with no issues what so ever. I knowingly can go drive my truck with confidence now and not worry about killing my ESC.
I have been running this mod for about 5 months now with no heat issues or any issues with my ESC :thumbup:
Traxxas centre CVD mod for Losi diff
Credit goes to revoroller as I followed his mod as to re-using the traxxas centre cvd.
I removed the red aluminium ring so I could remove the cup as it was not necessary for the mod. These are the parts I used to complete the mod.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0690.jpg?t=1346851072[/IMG]
Losi CV Driveshaft Rebuild Set #LOSB3505
Losi Front or Rear Diff/Differential Drive Yoke #LOSB3541
Du-Bro Flat Washer 2.5mm #DUB2108
Dia. 13mm Heat shrink cut 12mm long
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0703.jpg?t=1346851101[/IMG]
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0704.jpg?t=1346851119[/IMG]
The 2.5mm washer went on each side of cvd in the yoke to close the space and made a nice snug fit. I then heat shrinked around the yoke to keep the pin that is holding the cvd in place
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0705.jpg?t=1346851139[/IMG]
Losi lst2 diff cup exploded view and build detail
This is the only exploded view I found that uses the H.D. diff cup like I used in my build, which is for an 8ight Truggy. I may have misled in post #26 when I said that the diff required no shimming. I built my diff exactly as per the exploded view below. I shimmed 1 x 6mm shim under ring gear and 1 x 6mm shim on the opposite end internal diff cup.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/8ighttruggy.jpg?t=1347020342[/IMG]
and then followed the rest of this view that [COLOR="#0000FF"][B]revoroller[/B][/COLOR] provided in post #6
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/xxx.jpg?t=1347020401[/IMG]
I found that building my diff as per the 8ight Truggy exploded view that no additional shimming was necessary in the LST2 exploded.
Only in the diff cup and as shown where by me in post #26 photo #7.
Below is a link to the 8ight Truggy exploded view.
[URL="http://www.losi.com/ProdInfo/Files/8IGHT-T2RTRPartsList.pdf"]http://www.losi.com/ProdInfo/Files/8IGHT-T2RTRPartsList.pdf[/URL]
Shock rebuild & VDP (Varaiable Dampening Piston)
Here are my shocks before the rebuild. I was running 50W oil front and rear with a VDP #2 and green springs front and tan rear. This set up worked very well for me, but, I thought would try something different on this build.
I am going to try 60W oil front and rear with VDP #2 and gold spring front and black rear.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0717.jpg?t=1347032887[/IMG]
I stripped the shocks down to give a good clean and emptied the old shock oil out. I was happy that the old shock oil wasn't to dirty which meant my shocks were in a fairly good operating condition still. My shocks were last serviced about 6 months ago.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0718.jpg?t=1347032984[/IMG]
This is the VDP kit with valve on top, I am using piston #2.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0724.jpg?t=1347032958[/IMG]
I then filled my shock with 60W shock oil. I moved the piston up an down to let any trapped air bubble escape.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0726.jpg?t=1347032946[/IMG]
Here is an image of how full I made the shock before putting the bladder back in place and the rest of the shock back together.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0729.jpg?t=1347032934[/IMG]
The end result, a nice clean and easy rebuild.
[IMG]http://i1249.photobucket.com/albums/hh507/craig_mitch316/RPM%20%20build/IMAG0732.jpg?t=1347032630[/IMG]
