I was wondering if you guys could help me. I have the slayer with the short chassis and was wondering if I can use the center driveshaft and axles off the slayer pro?
Printable View
the center driveshaft doesnt seem like it would fit.. but it might.. the half shafts should though.
The front center drive shaft for the Slayer pro is the one that will be too long. It will work but you'll have to cut it down a bit or just get the original one. I found that out when I put the MIP center shafts on. Apparently they are made for the Slayer pro and the front shaft was about 1/8 inch too long and caused binding and I had to cut it down.
