Hi I have a summit 1/16 with the stock servo and I have an extra cc bec lying around and wonder if Itd be a good idea to put it in truck?
Sent from my DROIDX using Tapatalk
Printable View
I really do not see any benefit.
The stock servo is not a power hog by any means...
I think you would see a difference as you could get 6 volts to it vers 4.8 from the ESC. Plus the external BEC would offer more amps over the stock ESC. Not sure how man amps the stock servo could pull even at 6 volts. But I run them in my crawlers and I see how much they offer. Throw it in,, I say.
Where did you get the info that you only get 4.8v to the servos?
I was assuming but after checking the specs I am wrong. [url]http://traxxas.com/products/parts/escs/vxl3m[/url] It does say 6.0volts but does not list amps. I actually have a watt meter for my airplanes. I'll see if I can plug it in and get a reading on what amps it pulls when operating the servo.
Couldn't hurt anything, chuck it in there and tell us how it works.
Thanks for clearing that up, MaxxPain.
[QUOTE=MaxxPain;5008401]I was assuming but after checking the specs I am wrong. [url]http://traxxas.com/products/parts/escs/vxl3m[/url] It does say 6.0volts but does not list amps. I actually have a watt meter for my airplanes. I'll see if I can plug it in and get a reading on what amps it pulls when operating the servo.[/QUOTE]
Have you tried? I was looking at getting a 6-7.4v High torque metal gear servo, after 3 dead stocks i'm getting something better but I don't know if the stock reciever will supply a more powerful servo.
Yes it will... especially a 16th sized servo.
My Summit has 5 servos... two of which are 400+ in/oz torque monsters. The stock receiver had no issue having the current traveling through it.
The real question is if the internal BEC of the ESC is up to the task.
[QUOTE=Maxx_Adam;5348002]Have you tried? I was looking at getting a 6-7.4v High torque metal gear servo, after 3 dead stocks i'm getting something better but I don't know if the stock receiver will supply a more powerful servo.[/QUOTE]
I'm sorry, I have not measured it. I keep forgetting to bring it home.
