Found these...on 12 cell it looks to fast to drive!
[url]http://s127.photobucket.com/albums/p144/paulwf150/?action=view¤t=CIMG0193.flv[/url]
[url]http://s127.photobucket.com/albums/p144/paulwf150/?action=view¤t=CIMG0192.flv[/url]
Printable View
YES!! That looks so hard to control it will be fun!!!
Did it bottom out on a ramp that small? That was kind of surprising especially since it has stiffer springs that the 1/16th Slash.
Awesome!!!!!!!! Can't wait. My first one will be here Tuesday and my second one should be here wed. or thurs.
Wow! very fast!
[QUOTE=healthyfatboy]Did it bottom out on a ramp that small? That was kind of surprising especially since it has stiffer springs that the 1/16th Slash.[/QUOTE]
Definitely bottomed out. Not sure what to make of that
I think they have the same springs..
All that is need is a little more preload and they work just fine
Yeah but you never know how that person had the suspension set up. I do know however that his truck is very heavy if he is using 2 6cell nimh. I ordered the heavy springs for min cause I plan to do alot of jumping.
That's all apart of the fun of this hobby!
I had a 2s 5000mah lipo on my slash and the suspension worked good..
i ordered the aftermarket differential i wonder how much it keeps the front end from coming up
Gonna need thicker shock oil and a center diff for sure.
Isn't chassis slap normal? Also, they don't have much ground clearance considering the vehicle is less than 5" tall.
It sure is normal... you can of course put in some stiffer springs and increase ground clearance but then you can hardly drive straight anymore without flipping over. It's all about balance between handling and damping power.
Looking real sweet...anybody know if "buytraxxas" ships overseas ? was thinking of parts etc.
I preeordred mine @ Amain on 16/4...soon i hop it wil be here :)
/Tp
He's using two batteries, and traxxas suggests a different suspension setup for jumping with two batts.
Actually, the springs are different if you look at the part numbers between the two truck. They are much stiffer for the e-Revo vs. the Slash.
[QUOTE=healthyfatboy]Actually, the springs are different if you look at the part numbers between the two truck. They are much stiffer for the e-Revo vs. the Slash.[/QUOTE]
Wow! massive difference between the revo and slash.. 2x
[QUOTE=filmmaker]Wow! massive difference between the revo and slash.. 2x[/QUOTE]
i bet the tires weigh 2x as much too
