Brushless E-Revo Suspension FAQ
[I]This is where I will make my part of the BL E-Revo FAQ. It may be added on to and/or up-dated. [/I]
[B][SIZE="6"]Brushless E-Revo Suspension[/SIZE][/B]
[B]Index for suspension section[/B] (When making adjustments, always make sure the truck is sitting at ride height, in a sagged stance ready-to-run.)
[LIST=1][*][B][I] [SIZE="4"]Overview[/SIZE][*] [SIZE="4"]Rockers[/SIZE][*] [SIZE="4"]Ride Height[/SIZE][*] [SIZE="4"]Roll Center[/SIZE][*] [SIZE="4"]Sway Bars[/SIZE][*] [SIZE="4"]Springs[/SIZE][*] [SIZE="4"]Shock Oil[/SIZE][*] [SIZE="4"]Pivot Ball Caps[/SIZE][*] [SIZE="4"]Toe Adjustment[/SIZE][*] [SIZE="4"]Camber[/SIZE][*] [SIZE="4"]Caster[/SIZE][*] [SIZE="4"]Popular Accessories[/SIZE][/I][/B][/LIST]
1: [B]Overview[/B]
The Revo has a very complex suspension design that far surpasses that of any other monster truck. The combined performance and extreme suspension travel makes it truly unique The inboard design keeps the shocks out of harms way and away from the worst of the dirt and grime for long lasting performance and minimal maintenance. The Traxxas GTR hard-anodized teflon coated shocks are by far some of the smoothest operating shocks available for the Revo. They even have Titanium Nitride coated shock shafts (TiN) to help deliver smooth dampening action as well as a long life span. Connected to the shocks are the rockers which provide different amounts of progressive rates. The rockers are then connected to the lower a-arm by a push rod.
2: [B]Rockers[/B]
There are four rockers to choose from, stock being the P2's(90mm) which give a good overall balance of performance. The P1 rockers are best suited for rough terrain that requires a lot of suspension articulation. The P3 rockers on the other hand, are good for more street use or high speed cornering where body roll and rear squat is wanted to be a minimum. There is also another rocker that comes with the E-Revo, the LT rocker. It is the long travel rocker(120mm) and it is best suited for rock crawling or big jumps where you need all the ground clearance you can get.
3: [B]Ride Height[/B]
There are a couple things that will affect your ride height without changing the suspension parameters. You have the push rod location in the lower a-arm and the shock preload adjustment. In stock form the E-Revo has the pushrods set in the middle hole. Putting the rod in the inner hole will raise the ride height and lowers it when installed in the outer hole. If you need to finely tune your ride height, use the preload adjustment on the shocks. This is meant for small changes only.
4: [B]Roll Center[/B]
This is another feature that the E-Revo has packed into it. There are two holes in the front and rear that the upper a-arm can go into. This is where you adjust the roll center. Adjusting the arms into the lower holes will raise the roll center and the roll stiffness, acting like you have sway bars in a way.
If you add roll resistance to one end, lets say the back by mounting the rear arm in the lower holes, this will tend to add traction to the opposite end and possibly add more steering. The arms are mounted in the upper hole in the front and rear stock. These settings are more advanced and normally used for racing. When you change your roll center, you need to re-adjust your bump steer. See the chart in the caster section.
[IMG]http://www.traxxas.com/support/pub/images/front_rollcenter_s.jpg[/IMG]
5: [B]Sway Bars[/B]
Sway bars give the E-Revo less roll in the turns. This will help keep the truck from rolling over and planted on its wheels.
For the E-Revo, there are two main options available. There is either the [URL="http://www.impaktrc.com/product_info.php?products_id=2329"]Traxxas[/URL] sway bars or the [URL="http://www.impaktrc.com/product_info.php?products_id=1597"]Tekno RC[/URL] sway bars. Both are liked very well. Many people use these, and not just racers. Bashers also like to use them sometimes. This is another preference option that you can install if yous o choose to.
6: [B]Springs[/B]
The E-Revo is known to come with soft springs. This may be one of the first things that you want to do to help the performance of your monster. The stock in the front is white up front and green in the rear. Some people use the long travel springs to give a firmer ride. Since the E-Revo comes with these you can experiment some before you buy anything. If you decide that is too firm, you can buy different ones to suit your needs. Here is a chart showing the spring rates and colors.
[IMG]http://www.traxxas.com/support/pub/images/Revo-spring-chart.jpg[/IMG]
7: [B]Shock Oil[/B]
The E-Revo comes with 40wt silicon oil. When you change to a stiffer spring you may want to add different/thicker oil as well. If you do not change the oil with a stiffer spring combo, the truck may feels "springy." The thicker oil will help with this feel and will absorb bumps better. Different oils from different companies seem to vary on how thick they feel. So when you change oils, stick to that brand. The oils from one brand should be more consistent with each other.
To fill the shocks with oil: Take the shock off of the truck and clean it. You need to clean it so you do not get dirt inside of the shock body. Take the spring and retainer off. Take off the cap and dump out the old oil. You can clean the inside if you like. Fill the shock with oil to the top and move the shock shaft up and down slowly a few times to help relieve it from air bubbles. (very bad) set that one aside and move on to the next shock so the rest of the bubbles will surface. Once you get them all filled with oil and the bubbles are gone you can then put the shock shaft half way compressed. Put the cap on and screw it while holding the shock at an angle with the air hole in the cap facing down. At fisrt there should be some bubbles come out then it should be just oil. Once you have it screwed on snug, finish the others. [URL="http://www.youtube.com/watch?v=rixBJu93Qyw"]HERE[/URL] is a video that shows it in more detail.
8: [B]Pivot Ball Caps[/B]
These are in the axle carrier and are screwed to the a-arms. These allow the suspension to move up and down freely. If incorrectly adjusted, you could hinder your suspension performance. It should be adjusted with no free play, but still allow free movement of pivot ball. Here is a picture to show how you adjust it.
[IMG]http://i2.photobucket.com/albums/y9/carraig042/pivot-ball-cap-adjust-1.jpg[/IMG]
9: [B]Toe Adjustment[/B]
The toe adjustment is used to adjust the steering response. The stock setting in the front is 0 degrees toe, or strait forward and 1 degree toe-in on the rear. You adjust this by turning the turnbuckles with supplied wrench. You can see the angles by looking at an angle above the E-Revo.
[IMG]http://www.traxxas.com/support/pub/images/toe_front_s.jpg[/IMG]
10: [B]Camber[/B]
Camber is used to adjust the amount of bite that you have in corners. Using negative camber (stock=1* front and back), or tilting the top of the wheels towards to chassis will create more bite in the corners. Straightening the wheels, up and down will create less traction in the turns giving it a looser feel. To adjust this you have to take of the blue covering on the knuckles on the wheel side and use a 2.5mm driver to turn the pivot ball.
[IMG]http://www.traxxas.com/support/pub/images/camber_neg.jpg[/IMG]
11: [B]Caster[/B]
The caster affects the steering throughout the turn. Moving the clips to the front portion, which moves the a-arms back will create more steering. This setting is also by preference on how you like it to feel.
[IMG]http://www.traxxas.com/support/pub/images/caster_s.jpg[/IMG]
When you adjust the caster, you need to adjust the bump steer for the new angle. The E-Revo has only .1 degree of bump steer through the whole range of suspension travel. Here is a chart that show you where to put spacers according to the amount of caster you have.
[IMG]http://www.traxxas.com/support/pub/images/Bump-steer-chart_s_000.jpg[/IMG]
12: [B]Popular Accessories[/B]
There are many accessories that you can use for your E-Revo's suspension to make it lighter, stronger, more agile, and/or look better.
[LIST][*] Max Travel Steering Stop. This is included with your E-Revo. If you want your truck to be able to turn sharper, you can install this. You can refer to [URL="http://www.traxxas.com/PDF-Library/5605_manual.pdf"]Page 26[/URL] in the E-Revo manual to see how to do it. I will provide a picture How-to shortly to make the process easier. When you change to the max steering stop you will have to move your steering linkage to the outer holes on the servo arm.
[*][URL="http://www.buytraxxas.com/product_info.php?products_id=2957"]Variable Dampening Pistons[/URL] seem to be used by a lot of people, racers in specific. These will create a slower compression while increasing the rebound response. If you are on a rough surface the E-Revo will absorb the bumps better and keep the tires on the ground more.
[*] You can use the [URL="http://www.buytraxxas.com/product_info.php?products_id=2374"]Jato Dust Boots[/URL] to help the shocks life a long life with minimal rebuilds.
[*] Traxxas has different Aluminum pushrods available. You can use [URL="http://www.buytraxxas.com/product_info.php?cPath=1_1675_1672&products_id=2165"]These[/URL] with the progressive 3 rockers, and [URL="http://www.buytraxxas.com/product_info.php?cPath=1_1675_1672&products_id=2223"]These[/URL] with the LT rockers, Progressive 1 rockers, and the Progressive 2 rockers when you insert a [URL="http://www.buytraxxas.com/product_info.php?products_id=2131"]Spacer[/URL] on either end of the push rod.
[*] There are T6-7075 aluminum toe link/turnbuckles. They are available in [URL="http://www.buytraxxas.com/product_info.php?cPath=1_1675_1672&products_id=3076"]Black[/URL] or [URL="http://www.buytraxxas.com/product_info.php?cPath=1_1675_1672&products_id=2489"]Red.[/URL][/LIST]
[I]
Pictures and paraphrasing used from [url]www.Traxxas.com[/url][/I]
-Brett
