Running in the mud and I got a lot of crud up in the gears. I bought the RPM cover so I could fully seal the pinion/spur area. Doesn't fit though. The stock cover it very thin at the base. This is required as the rear bumber mount comes forward ever so slightly. Since the RPM cover rises from the base, this mount pushes the rpm cover a little bit forward causing the holes not to line up.
